Re: McCormick-Deering 10-20 trying to fire
Posted by spiffy1 on November 21, 2008 at 07:14:47 from (70.41.137.72):
In Reply to: McCormick-Deering 10-20 trying to fire posted by Dave Koenigsfeld on November 19, 2008 at 15:26:12:
Mike Androvich said: (reply to post at 22:06:30 11/20/08 )
Hey Mike, think I saw your W-14 in a book the other day; sweet! 8)
Sorry Dave, off topic.... back on...
Yep, sounds like you got it; no it doesn't matter where you start- however different books might show different as many mags put a "1" mark on one of the terminals of the cap so you could remove wires later without checking the starting point. The 10-20 alone I'm guessing saw at least 3 different mags from the factory: Dixie, E4, F4 I think; the former two - again if I'm thinking right - turn the same way but have a different "1" marker - so the same drawing would work absolutely fine for either, it'd only make someone later do a small double take if #1 on the block didn't match #1 on the mag.
