Re: M flooding
Posted by CSF on November 21, 2008 at 08:58:02 from (207.179.178.242):
In Reply to: M flooding posted by grant nelson on November 20, 2008 at 16:44:53:
Grant....you may try removing your carb. float and give it a "shake". If there is some gas inside it, it won't operate your needle valve correctly. Had to change mine a few weeks ago, must have been a pin hole in it. Same symptom as you have. Good luck.
