Re: M Farmall Napa 6v coil update...... Honda parts?
Posted by TheDurk on November 21, 2008 at 13:50:01 from (72.76.180.25):
In Reply to: M Farmall Napa 6v coil update...... Honda parts? posted by Dave in CT on November 20, 2008 at 18:17:28:
John G. Hasler said: (quoted from post at 17:25:42 11/21/08) > if you have a 12 volt system a resistor is
> required in some form or points will have a
> short life.
The coil will also have a short life. It will overheat at low rpm due to the long dwell time.
I agree with everything except the last eight words. The dwell time as a percentage of each second or minute does not change with RPM, unless you count zero, when it 'dwells' as long as the points are closed to start with. The length of each power cycle is greater, but so is the cool-down time, both being in milliseconds. I would think it would overheat equally at any RPM.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
