Re: Delco Regulator
Posted by Janicholson on November 23, 2008 at 06:51:42 from (66.173.50.91):
In Reply to: Delco Regulator posted by brian2 on November 22, 2008 at 17:00:55:
It is likely to work. There is a possibility that it is for the B type generator which you do not have. If the seller will check it you will know.
Have the seller check to see if the F terminal is connected to the ground of the regulator base with an Ohm Meter. If it is, it should show almost no resistance. It is correct foe it to be a grounded terminal for the A type generator on yours. JimN
