Posted by Janicholson on November 23, 2008 at 07:26:46 from (66.173.50.91):
In Reply to: 300u starter switches posted by Rick Bachman on November 22, 2008 at 11:04:27:
I have a clear image in my head of what you have. The toggle switch has its input wire hot at all times. the two wires leaving are going to be powered from that switch when it is on, and no power will flow when off. The switch is wired correctly. The wire going to the push button momentary contact is correct to supply that switch with power. that switch then is connected to the starter S terminal on the relay on the starter. Again correct. The other wire on the toggle goes to the ignition coil to give it running voltage. It is correct. The toggle switch is bad. Disconnect the coil where the lead comes into it (small probably minus marked terminal) Use a jumper wire to jump across the toggle switch terminals nothing should happen, if it does there are possible shorts in a wire going to the coil. Now test for volts at the disconnected coil wire (it should be battery volts). Push the starter button (it should spin and crank (neutral is a good idea)). Now reconnect the coil and start it! Needs a new Toggle switch, get a water resistant one that handles 20 or so amps. JimN
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
