Posted by Janicholson on November 23, 2008 at 08:08:53 from (66.173.50.91):
In Reply to: Re: Muffler Removal? posted by Clarkbug on November 23, 2008 at 07:51:20:
Two chain wrenches put on 180 from each other with two people using 3 foot pipe cheaters on the wrench handles might do it. The two wrenches keep the side load on the pipe from breaking it off. The effort might also loosen the rust holding the muff on. JimN
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
