Re: H Carb. Problems
Posted by Janicholson on November 23, 2008 at 08:18:12 from (66.173.50.91):
In Reply to: H Carb. Problems posted by Tweeter on November 22, 2008 at 12:53:47:
With the carb installed, pull the bowl off and hold up gently on the float. open the fuel valve, and see if it shuts off the fuel. Let it down and get a little out, lift and it shuts off. If it will not, it will be obvious where it is coming from. If it does shut off, it is binding against the bowl. It is a tight fit, and may need adjustment to clear. JimN
