Posted by JimB2 on November 23, 2008 at 08:54:50 from (99.241.179.24):
In Reply to: Block heater for 484 posted by Michael Price on November 23, 2008 at 08:07:55:
Michael, a tank heater is the easiest to install. There is a plug at the front of the water manifold at the right front of the engine and there is a drain plug in the side of the block just above the starter. So buy a recirculating tank heater some heater hose, some pipe nipples, connect tank heater outlet to water manifold and inlet to drain plug by starter. Fabricate the mounting bracket so the top of the tank heater is below the drain plug. Route the heater hose from the water manifold around behind the fan and alternator and to the outlet of the tank heater. I tried to find a picture on the Internet of a 484 with tank heater but the best I could find was a 574. Notice tank heater is that silver cylinder mounted against front bolster. We have ours mounted between injection pump and starter.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
