Re: OT For John T....
Posted by Janicholson on November 23, 2008 at 10:08:53 from (66.173.50.174):
In Reply to: OT For John T.... posted by Dellbertt on November 23, 2008 at 09:48:29:
I assume you are using Coaxial cable from the antenna to the boxes. Twin lead will not do the trick, it is unshielded. Grounding Circuits will help in many cases, I believe a filter at each TV is the larger complex answer. Try the 40$ suppression filter power strips then progressively go more expensive until satisfied.
Tips"
Check the grounding rod on the electrical systems neutral and ground bus (these two should be bonded together) If it is a iron post, or old and corroded, purchase a new ground rod and pound it in near the Circuit/Entry box. It should be attached to the neutral with a #8 solid copper wire.
If the individual circuits to the TVs have no ground wire in them, it will probably be useless to put a filter in a circuit that has no way to "ground the spikes" replacing those may also be needed. Good luck, JimN
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
