Posted by Gene Bender on November 23, 2008 at 15:35:05 from (67.55.226.167):
In Reply to: Muffler Removal? posted by Clarkbug on November 23, 2008 at 07:19:48:
Does the propane torch get the metal red hot as thats the only way you will get the muffler loose as irs probably rusted fast if not welded fast. If you want to remove the pipe from the manifold you will need more than a propane torch as it will have to be pretty red hot to get the pipe to unscrew then a large pipe wrench to turn loose an oxy-ace torch it what you need.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
