Re: 706 Running Hot?
Posted by Heat Houser on November 23, 2008 at 19:00:49 from (69.66.35.73):
In Reply to: 706 Running Hot? posted by BigSky on November 23, 2008 at 18:32:50:
A typical temperature drop (difference) between the top radiator tank and bottom tank will be around 12-16 degrees. (Must be hot enough for the thermostat to be fully open when measuring) If little difference, something is wrong with the air flow, plugged fins, slipping belt, fan on backwards, etc. If a large difference, the problem is with coolant flow, tubes plugged, water pump impeller broken, stuck thermostat, etc.
