Re: Farmall Distributor Installation (Need Help)
Posted by El Toro on November 24, 2008 at 04:15:22 from (205.188.116.73):
In Reply to: Farmall Distributor Installation (Need Help) posted by Rodney in Kansas on November 23, 2008 at 20:01:46:
If both valves are closed on No1 piston you should be at TDC on the compression stroke. Your firing order should be:
2-1
4-3 Your rotor should be aligned with the No1 plug tower when the distributor is installed. Hal
