Re: 706 Running Hot?
Posted by El Toro on November 24, 2008 at 04:29:52 from (205.188.116.73):
In Reply to: 706 Running Hot? posted by BigSky on November 23, 2008 at 18:32:50:
The tubes in the radiator may need to be rodded out. I wouldn't run the tractor until you find the problem as you can damage the head and engine quickly. Any of the problems mentioned can cause it to overheat. Hal
PS: When its hot touch the bottom hose to see if it is hot. Be careful not to get burned. If it doesn't feel very warm the tubes may be plugged
restricting the coolant flow.
