Re: Farmall Distributor Installation (Need Help)
Posted by CNKS on November 24, 2008 at 05:18:45 from (216.144.104.128):
In Reply to: Farmall Distributor Installation (Need Help) posted by Rodney in Kansas on November 23, 2008 at 20:01:46:
#1 at TDC, mark on pulley aligned with pointer, rotor pointing to #1 distributer terminal. Install, turn distributer counterclockwise, remove coil wire from dist, hold close to nut on distributer (switch on), rotate dist clockwise until you get a spark, lock dist down, fine tune by ear after engine starts and is warm. Firing order is cast into block in plain sight, 1,3,4,2, #1 is next to radiator. dist terminals are arranged
21
43
