Re: Leftover Parts after Overhaul
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by The Red on March 29, 2000 at 04:16:13 from (12.75.197.217):
In Reply to: Leftover Parts after Overhaul posted by Greg Meadors on March 28, 2000 at 20:32:49:
Greg the primary drain plug is the one under the PTO since it is at the bottom of the case. So yes you did NOT get all the old 90W out.
The three washers go on the three studs that are located through the somewhat center of the head. There is a stud between 1 and 2 cylinders towards the pushrods, one pretty much in the center between 2 and 3, and one offset between 3 and 4.
Post A Followup
: Re: Re: Leftover Parts after Overhaul
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
