Posted by John having problems no m on November 24, 2008 at 07:04:18 from (68.62.56.183):
In Reply to: Re: pulling dampner posted by Owen Aaland on November 22, 2008 at 18:00:32:
My puller needed a little coaxing. The dampner is off ! I kept the 3 original bolts threaded into the holes a few turns, then had to replace them with 3 longer bolts as the dampner moved forward until it finally pulled clear off the crank. Thanks for your help. BTW, this dampner is nothing like what you would see on a car, the center is solid with 3 bolts holding it to the end of the crankshaft. The crank is so big it has (3) 3/8 holes drilled and tapped into the end of it, 120 degrees apart. The dampner is held tight to the crank with these 3 bolts, but these bolts are the only thing you can push against to remove the dampner. hope my words are painting a decent picture. John.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
