Re: WD-9 and MD
Posted by Haas on November 24, 2008 at 12:13:03 from (12.65.12.109):
In Reply to: WD-9 and MD posted by H fanatic on November 21, 2008 at 16:59:45:
The WD-9 engine will not fit in the M chassis without major modifications. If you find an MD engine or and engine from a WD-6, it will not fit in the M chassis either. The MD engine is longer than the M gas engine and therefore the chassis on the MD is slightly longer than the M. The side rails on the MD are longer than on the M.
