Re: 200 NOW FIRES!
Posted by El Toro on November 24, 2008 at 15:19:21 from (205.188.116.73):
In Reply to: 200 NOW FIRES! posted by LMack on November 24, 2008 at 14:49:40:
You are not getting any gas into the engine. You need to hold your hand over the throat of the carburetor while someone makes an attempt to start the tractor. If there's very little suction
means there's very low intake manifold vacuum. You need to make sure the intake manifold is tight and the carburetor is too. Check your valves to make sure they have enough clearance. Set them at .017" cold. Did you blow out and clean all the jets in the carburetor? You should be able to start the engine while holding your hand over the throat. Hal
