A quick check of resistor function is to temporarily bypass the resistor by jumpering the two terminals together. If the engine starts/runs OK with the resistor bypassed it means either the resistance is too high or the resistor is open-circuited.
On my Super M I mounted the resistor with a 5/16" bolt thru a conveniently located (and unused...) hole in the gas tank front support bracket. However most of 'em I see are mounted alongsdie the coil using one of the coil clamp bolts.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
