Re: 12 volt resistor on my H
Posted by Bob M on November 25, 2008 at 04:38:45 from (151.190.254.108):
In Reply to: Re: 12 volt resistor on my H posted by Minnesotan H on November 24, 2008 at 19:09:15:
Depends on the alternator and how it's wired up.
For the Delco 10SI (most common alternator used for 12 volt conversions) you need either a resistor, warning lamp or diode in the circuit between the ignition switch and the alternator #1 terminal.
The alternator will work without a resistor, etc. However without it and if the tractor has coil & distributor ignition, the alternator will "back feed" the coil after the ignition is turned off causing the engine to continue to run.
