Posted by PA Steve on November 25, 2008 at 07:38:03 from (209.222.221.159):
In Reply to: MD gas start linkage posted by jfrankhash on November 24, 2008 at 18:47:36:
If your problem is that the butterfly valves in the intake manifold are open when they should be shut, that can be corrected by adjusting the length of the lever that goes to the arm that controls the butterfly valves. If your problem is that the carburetor fuel shutoff is off when it should be on, you may have the arm hooked up on the wrong side. You need to take the carburetor off and look at which position is on and off on the carb. Then move the linkage without the carb hooked up. You"ll probably find the problem. Your linkage could be far enough out of adjustment that someone hooked it up incorrectly last time it was taken apart. Good Luck!
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
