Re: 6 volt to 8 volt?
Posted by Janicholson on November 25, 2008 at 10:03:33 from (199.17.6.26):
In Reply to: 6 volt to 8 volt? posted by 1951farmallh on November 25, 2008 at 09:48:19:
If it is free, do it. Adjusting the voltage to a bit over nine might be needed. Bulbs will be bright, but not explode. The use of O gauge cables is a good idea. Charging is a problem. It might charge on a 6 volt set to high charge. If using 12v, watch it like a hawk, do not leave it, and check for temperature. JimN
