Re: 1945 M will not start! HELP!
Posted by El Toro on November 25, 2008 at 14:59:55 from (64.12.116.73):
In Reply to: Re: 1945 M will not start! HELP! posted by KStatz_Indiana on November 25, 2008 at 13:22:38:
Be careful when jumping across the small terminals
make sure the tractor is out of gear and the brakes set. One of those small terminals should have an S on it. That only gets voltage while cranking the engine. The other small terminal should have voltage on it all the time and proably feeds voltage to your ignition switch, lights and starterbutton or to a key start
switch. Hal
PS: If your battery cable is connected at the solenoid you need to remove the battery ground and remove the battery cable at the solenoid and clean the cable until shiny and if corrosion is on the solenoid clean it too. Then reconnect the battery cable and reconnect the ground cable last.
