Re: coolant passage rust removal
Posted by Janicholson on November 25, 2008 at 17:22:19 from (66.173.50.78):
In Reply to: coolant passage rust removal posted by Brad Motheral on November 25, 2008 at 17:17:27:
Use washing Soda and water (one cup per gallon of warm water, or a little stronger) to fill the block (do not get it in anything but the water jacket, or on you, as it is caustic) A strong mix will break down the rust flakes. then flush it out well. Removal of the side access is also a good idea if some mechanical cleaning is needed. JimN
