Re: 1945 M will not start! HELP!
Posted by Dr. Bert on November 25, 2008 at 18:28:27 from (72.36.57.58):
In Reply to: 1945 M will not start! HELP! posted by KStatz_Indiana on November 25, 2008 at 09:02:50:
KStatz: In my little town the "long necked" push button starters are hard to get--so I rebuild the old ones. It is very simple-- pry up the tabs on the bottom that hold in the base, you will find a wedge-shaped copper contact. Clean it 'til its bright and also the contacts at the posts. I routinely replace the insulation on either side of the wedge-shaped contact--usually with plastic trimmed from a coffee can lid. Reassemble--bend the tabs back in place and check across the posts with a multimeter while depressing the button.
