Posted by KEB1 on November 25, 2008 at 20:14:42 from (63.228.85.58):
In Reply to: 6 volt to 8 volt? posted by 1951farmallh on November 25, 2008 at 09:48:19:
An old tractor (or car) with a cutout relay will charge an 8 volt battery, just a little slower than it will a 6 volt one. With a voltage regulator, the voltage cutout relay inside the regulator has to be adjusted to produce a higher voltage, or the 8 volt battery will never charge properly. Not difficult if you have some knowledge of the inner workings of a voltage regulator and a decent voltmeter.
My '43 H still has the cutout relay, but someone could have changed yours to a regulator somewhere along the line.
Using an 8 volt battery is a quick & dirty work-around for a poorly maintained 6 volt system. A 6 volt system with a good battery and properly sized cables (at least 2/0, bigger is better) will spin the engine over plenty fast enough, even when its really cold.
Running on 8 volts will shorten the life of any bulbs, although they will be a little brighter until they die. Had an old Willys jeep that someone had put an 8 volt battery in, ended up going to back to 6 volts.
Use it if you want and its free, but there's really no reason to change from a properly maintained 6 volt system.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
