Posted by mattofvinings on November 26, 2008 at 09:54:15 from (198.208.159.20):
In Reply to: '48 H Hydraulic Hoses posted by chad504 on November 26, 2008 at 06:43:55:
I would be with El Toro on this...use NPT to JIC male, put JIC female fittings on both end of the hose. This way you never have to fight with the hose or rotate the entire hose (if one had an NPT male crimp fitting)
Often if you can layout the hose path with something like a garden hose or a scrap piece of wire you can arrive at a length. Take this to the hydraulics shop with you.
If you use the "reusable" fittings as El Toro has pictured I find a couple drops of cheap rear axle lube (EP oil) to be the best assembly lube.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
