Re: '48 H Hydraulic Hoses
Posted by El Toro on November 26, 2008 at 10:59:47 from (205.188.116.73):
In Reply to: Re: '48 H Hydraulic Hoses posted by mkirsch on November 26, 2008 at 10:28:50:
third party image
Any hydraulic store will carry them. We used a lot of Aeroquip hose. Parker and Alemite are just as good. If you know the lemgth and size of hose and what ends you want to install on hose you can have your wife or friend pick them up. I like using the JIC fittings and swivel nuts on the hose. It makes for an easy connection. You can get straight swivel nuts or 40 degrees or 90 degrees. If its in an area hard to access I would use one of the angle swivel nuts. My garden tractor hydraulics will pick up the plow and sleeve hitch easily. Hal
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
