if it has a three terminal solenoid on it, there will be two big terminals, one from the battery, the other to the starter. the third terminal will be a small postusually on the top. the small post is where the hot wire from your starter button will go, that terminal will cause the solenoid to close when the starter button is depressed, causing the starter to engage. on the big terminal on the solenoid coming from the battery, there should be a good size wire, prolly #10 that would feed the tractors electrical system ie lighting and starting circuit. if it has a 4 post solenoid, 2 big and two little posts, on some older cars, the second small post would only be hot when the solenoid engaged the starter. what they did there is run a separate wire from that post directly to the ignition coil, (bypassing the ballast resistor) so it would put 12v directly to the coil, giving a hotter spark on startup. when you relesed the starter button, that circuit would then shut off and the coil would be fed power thru the ballast resistor. some of the older fords ran that set up, and some of the early gm's would do that, but from a starter mounted solenoid.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
