Re: 12 volt converson
Posted by mkirsch on November 27, 2008 at 08:41:09 from (67.240.251.254):
In Reply to: 12 volt converson posted by Mike Farmer on November 26, 2008 at 13:23:15:
A kit? No.
Quite frankly, though, a conversion is not that big of a deal.
Here's why you'd do a 12V conversion:
1. Tractor has no electrical system at all.
2. Existing generator is shot and needs to be replaced.
Do NOT convert because of a slow starter. That is either a starter problem or a battery cable problem. It has nothing to do with the generator.
If your generator is charging properly, then you do not need to convert to 12V.
