If it is loose enough to slide in W/O tools, it may fracture at the top and drop into the lower end (not good) Putting Iodine (the medicine)on it with it dry and clean and a bit of water mist to set it in place will rust it to the bore. This does work, but is tough to remove. Others have put Locktite sleeve liquid on them to hold them. I think this reduces the transfer of heat. IH had A, B C, and D sized bores and select fit sleeves into them. (stamped near the sleeve ring on each) If only ssuppliers would make sleeves to those sizes. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
