Re: Farmall Super H won't run
Posted by ScottyHOMEy on November 27, 2008 at 17:26:20 from (70.105.234.190):
In Reply to: Farmall Super H won't run posted by Old Tractors on November 27, 2008 at 15:18:29:
I think Jim has it nailed for you. Could end up bein' the condenser but it sure sounds like a bad coil. If so it WILL be HOT.
As far as not showing any charge, could be a lot of things. Have you tried polarizing the generator? That's a common cause of not charging. Apart from that, runa search on this site for "John T" and "troubleshooting" which will get you to his very helpful troubleshooting guide and will walk you right through narrowing down the problem.
