Posted by Mike Farmer on November 28, 2008 at 00:19:47 from (86.31.84.127):
In Reply to: Help with block repair posted by Dr. Bert on November 27, 2008 at 20:40:30:
I should be very interested in thoughts about silver solder as its something I have considered in the past. In answer to your existing problem there are several ways all of which you mentioned. Ultimately if the cosmetic appearance is not terribly important, bolt a patch of 3mm mild steel over it. I would suggest large enough to overlap it by about 1" all around. You will need to drill and tap the casting at about 1" intervals around the circumference of the repair and use a good quality sealant. Take Care. MTF
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
