Steve, If the tractor was driven over the edge of a ditch bank at the end of a field with the planter on, the planter can catch the bank and raise the 3pt. to high. The stop for the internal 3pt arm is in the center of the houseing. Can push it out. If this tractor has the closed center hyd system have seen them pushed out when the 3pt. was not even in use. You will have to remove the seat and floor from the cab. Remove fuel tank, lines linkage ect. as needed under cab. Lift off with a cherry picker. New houseings were made heavier. Have welded some. Can usually find a good used one.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
