Re: Farmall B Hood Year
Posted by CNKS on November 28, 2008 at 17:58:13 from (216.144.104.128):
In Reply to: Farmall B Hood Year posted by JJR on November 28, 2008 at 17:52:09:
39 or 40. Also if the engine is original the engine serial is the same as the original chassis serial. Engine serial is stamped below the #1 spark plug. Beginning serials for each year are listed under Research and Info to your left. Also casting codes in the form of 1*8*J are on most of the major castings, but may be few and far between on an early B. The J means 1940, 1939 is I, etc.
