Re: Farmall 300 Generator to Alternator Conversion
Posted by Jeff B. on November 28, 2008 at 21:06:58 from (69.20.162.151):
In Reply to: Farmall 300 Generator to Alternator Conversion posted by IHPRIDE on November 28, 2008 at 14:17:13:
This website has lots of information on converting them: http://www.geneseeproducts.com/
The only thing they don't mention is the fact that you can use the pulley from your old generator on a delco alternator so you don't have to mess with figuring out the belt thing. You can still run the old wide belts that way. Don't worry about the little fan on the front of the alternator, just throw it away. Those old tractors don't turn fast enough or hard enough for heat to be an issue.
