Bring No1 piston near the radiator to TDC on the compression stroke. Remove No1 sparkplug and hold your thumb over the plug hole while someone hand cranks the engine until the piston is at TDC. Then remove the cap and see where the rotor is pointing. It should be pointing to the No1 plug tower on the cap. Both valves on No1 should be closed when you're at TDC on No1 cylinder. If the rotor is off you will need to pull the mag or distributor and turn the rotor so its near the 1 & 2'o'clock position and reinstall. The plug wires need to go to the corresponding plugs in this firing order from the cap to the plug: Hal PS: The rotor turns CW. 2-1 4-3
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
