Posted by Janicholson on November 29, 2008 at 06:59:03 from (209.191.204.169):
In Reply to: Re: water in cylinder posted by IndiRon on November 28, 2008 at 19:14:42:
The sleeves in that engine are dry (pressed into the cast iron of the block full length contact. Rarely do they come out easily with the piston in the cylinder, as the piston ring rust has swelled the ring and sleeve so that they are tight. Some crack the sleeve, and cast bore as well. Getting the piston out can (in extreme water corrosion) require it to be removed in pieces. Drilling out the top just inside the rings with a circle of holes, and cutting down beside the pin with a recipro saw or similar. Good luck, JimN
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
