Re: water in cylinder
Posted by Janicholson on November 29, 2008 at 06:59:04 from (209.191.204.169):
In Reply to: Re: water in cylinder posted by IndiRon on November 28, 2008 at 19:14:42:
The sleeves in that engine are dry (pressed into the cast iron of the block full length contact. Rarely do they come out easily with the piston in the cylinder, as the piston ring rust has swelled the ring and sleeve so that they are tight. Some crack the sleeve, and cast bore as well. Getting the piston out can (in extreme water corrosion) require it to be removed in pieces. Drilling out the top just inside the rings with a circle of holes, and cutting down beside the pin with a recipro saw or similar. Good luck, JimN
