Posted by migraine on November 29, 2008 at 09:29:16 from (67.182.151.248):
In Reply to: 656 noise posted by Scott in Illinois on November 29, 2008 at 09:10:53:
Sounds like a hydraulic pump related issue. I bought a 966 a few years back that had the wrong pump gear installed and was a 3 degree difference in gear pitch. You could not stand to listen to that noise. Could be also cavitating noise from low fluid or partially plugged hyd filter. If the steering ,TA or brakes seem slow or not always functioning correctly you could have main hydraulic pump issues just around the corner. The oil probably is from stuck rings and may come out of that with a good hard workout. A half hour on the dyno or disk can do wonders for these old girls. Migraine
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
