Remove the spark plugs, Remove the valve cover, and the rocker shaft, rockers, and push rods. Be careful to not pull lifters out of their bore, sometimes the pushrods get a suction fit to the lifters, be patient, and keep them in order frnt to back. You will need a lever type valve spring compressor, and a 2' piece of 1/4" cotton rope. Use a 9/16" deep socket as follows. Use a plastic faced hammer and the socket (alone) to loosen each valve keeper. Place the socket o the valve keeper so the socket covers the stem. Rap the socket modestly with the hammer. This breaks the bond of the keepers to allow easy removal. Pull the plugs out. In number one cylinder, push in all but 6" or so of the rope. Hand crank. or use the fan belt to turn the cylinder untill the rope is compressed into the valves holding them up in place. Put it in gear to keep the engine from turning backward. Now use the spring compressor to remove the keeper and spring. Put on the seal as directed in the material supplied with the seals. All cylinders are done in the same way. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
