Posted by Bob on November 30, 2008 at 12:28:52 from (69.178.228.68):
In Reply to: 966 alternator wiring posted by markinab on November 30, 2008 at 11:55:10:
Is this the type of alternator you have... Delco 10SI/12SI?
If so, the #2 (RH in the photo) terminal is "voltage sense", and will have battery voltage at all times.
The #1 (LH) terminal is "switched excite", and will only have power when the key switch is "ON".
Instead of the diode shown in the photo, your tractor will have a resistor that accomplishes the same thing... to limit the reverse flow of current out of the alternator through the "excite" terminal. Also, the #2 wire will likely NOT be connected to the output stud, but will be connected to a point nearer to the battery for BETTER voltage sensing (although the setup shown will work just fine, and is often used in alternator conversions.
To recap... #2 always "hot", #1 only "hot" when key switch is "ON".
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
