Re: operating a log splitter
Posted by leroy in ne on November 30, 2008 at 13:18:19 from (67.63.106.62):
In Reply to: operating a log splitter posted by jim billings on November 30, 2008 at 12:04:49:
it can be done. however run 1 hose from hyd. outlet to in side of open center 2 way valve and a return to pump fill pipe on pump, pressure outlet lines on valve go to 2 way splitter cylinder. note this will not have a lot of splitting power as an H hyd pressue is in the area of 700 psi and most splitters use 2000 to 2500 psi pumps
