Re: H Blown Engine
Posted by El Toro on November 30, 2008 at 14:10:33 from (64.12.116.73):
In Reply to: H Blown Engine posted by Jarhead on November 30, 2008 at 13:20:11:
You need to pull the engine and tear it completely down. You need to inspect that block closely for any cracks in that sleeve area. You need to have your head magna-fluxed for cracks. The crankshaft needs to measured for wear by your local auto machine shop. They can furnish the correct bearings too. It may need to be ground undersize. I would install a new sleeve kit too. I would find some good used rods and have your auto machine shop to install the new pistons
on the used rods. This should get you started. Take a lot of pics and make notes as they will come in handy during the rebuild. Probably time to have the clutch rebuilt. Hal
