Re: H Blown Engine
Posted by mattofvinings on November 30, 2008 at 14:34:50 from (67.142.161.30):
In Reply to: H Blown Engine posted by Jarhead on November 30, 2008 at 13:20:11:
Agree that it's time for a complete rebuild. Good news is that you shut it down before a rod poked thru the side of the block.
Before going deeper I think I'd remove the oil pan and then #1 rod, then see about hand cranking it over. I think you'll know if anything else has been damaged. Without any compression it should be just the drag of the other rings in their bores - there should be enough oil in the journals not to damage anything.
Also very important to thoroughly clean the lower end of the engine to get any pieces/parts out of there.
