Re: Really hot brake housing on 1256
Posted by Ted in NE on November 30, 2008 at 16:39:20 from (74.85.105.73):
In Reply to: Really hot brake housing on 1256 posted by Baelee05 on November 30, 2008 at 14:35:00:
If the tractor has a cab make sure the floor mat is not between the pedal and the edge of the platform. It only takes a small movement of the pedal to lightly put the brake on. The screw in the brake valve spool can also come loose & put the brake on. The brake pedal has to come back solid against the edge of the platform.
