Posted by jonathan mirgon on November 30, 2008 at 16:51:29 from (4.224.228.215):
In Reply to: H Blown Engine posted by Jarhead on November 30, 2008 at 13:20:11:
In my opinion it would be best to do a complete overhaul, first verify that there is no block damage. As someone else said replacing only the broken liner and piston etc is not the correct way to fix it right. Get the crank re-ground and replace main and rod bearings, pistons , rings and liners. If done right your tractor will easily than outlast the operator. I have a 52 super c that I am restoring. When I purchased it smoked upon startup and had a big lack of power. Although it ran I decided to do a complete overhaul and make it run like it should. When I tore it apart I found all original IH parts inside of it. So if rebuilt corectly they will run a long time. Good luck with your project !
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
