Posted by bc on November 30, 2008 at 17:56:45 from (68.88.175.43):
In Reply to: 656 noise posted by Scott in Illinois on November 29, 2008 at 09:10:53:
Went through that with my 2606 which has the same hydraulics. Clean the screen with brakleen and change the filter. Keep it 5 gal over full. You can get a wix filter next day from Oreillys if necessary unless they happen to have it in stock.
It is near impossible to change the hytran and get all water out of the oil. Later you will just get more. Unless you are getting down to zero where the hytran is really icing up, the cold fluid thickens this time of year in cold weather and then has trouble flowing through the dirty screen.
It is hard to get clean fluid after a change cause the draft control housing under the seat also holds a few gallons and probably has a layer of sludge in the bottom of it. Wouldn't hurt to clean it out sometime though. Then all your lines and cylinders still have the old fluid which is hard and expensive to chase out.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
