Re: h farmall what is it
Posted by CNKS on November 30, 2008 at 18:18:15 from (216.144.104.128):
In Reply to: h farmall what is it posted by bowtieih on November 30, 2008 at 18:14:06:
Probably grease fittings that the previous owner installed. Really not necessary.
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
