Posted by Janicholson on November 30, 2008 at 18:23:06 from (66.188.163.79):
In Reply to: h farmall what is it posted by bowtieih on November 30, 2008 at 18:14:06:
The nose cone of a mounted corn picker attached to the "nipples" allowing the nose to follow the turning of the wheels left and right. The parts are standard with a mounted picker. They replace the axle nut, and are pinch bolt locked. JimN
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa
... [Read Article]
Latest Ad:
[More Ads]
